Hi community,
Currently we are encountering a behaviour similar to these posts on Distinguishing devices by Product Code & Revision and Yaskawa differing by Hardware Revision where:
OrientalMotor has a MultiAxis drives series which has types of 2, 3 and 4 axes but they are all using the same Product ID where the only way to differentiate them is by its Revision Number.
The RMPnetwork currently consists of a 3-axis type drive and two 4-axis type drives where both models are using the same Product ID with different revision numbers
This creates an issue where the 3-axis type drive is detected as a 4-axis type drive and follows its CustomNodeInfo configuration with an additional axis:
- We mapped the Product ID to follow the 4-axis type drive but the 3-axis drive is unable to transition into Operational as it is missing certain PDOs (0x1A31, 0x1A32 etc. for a 4th axis that doesn’t exist in the drive)
- Including or excluding the PDOs using PDOAssignments doesn’t work as well
- Attached is the ESI file for the MultiAxis series drives
[00:02:41.438] ‘Drive 12 (AZD4A-KED)’ (1013) ‘PS’: CoE (‘InitDown’ 0x1a32:0) - SDO Abort (‘Object does not exist in the object dictionary.’, 0x06020000): ‘download pdo 0x1a32 entries’.
May I know if there is any alternative way to differentiate between both these models with the same Product ID but different revision number?
- We have also tried requesting the vendor whether it would be possible to add the PDOs (0x1a30, 0x1a31… etc.) to the 3-axis type drive as a workaround to bypass the PDO error even though the PDOs would not actually be used
- However, we are unsure whether the vendor will be able to accomodate this request
Your help and clarification is much appreciated. Thank you!
Hi @gregory,
Thanks for the ESI file and the log. You can make this work on 11.1.0 with one CustomNodeInfo.xml entry. We will also add revision support to CustomNodeInfo.xml.
What we found
Your ESI file has a separate device for each model. All models have the same Product Code (0x13AF). Only the Revision Number is different:
| Model |
Revision Number |
| AZD4A-KED |
0x11110301 |
| AZD3A-KED |
0x01110301 |
| AZD2A-KED |
0x00110301 |
- The RMP uses the ESI device whose Revision Number matches the drive exactly. Each drive then gets the correct PDOs.
- If no ESI device matches, the RMP uses the device with the highest Revision Number for that Product Code. That is the AZD4A-KED.
- We think this is why your 3-axis drive got the 4th-axis PDOs (
0x1A3x).
Step 1: Send us your Revision Numbers
- In RapidSetup, discover the network.
- Open the node page for each Oriental drive. Record the Revision.
- Post the values here.
If all values are in the table above, do Step 2. If a value is not in the table, tell us before you continue.
Step 2: Use this CustomNodeInfo.xml entry
- Put the ESI file in the ESI folder. Remove older versions of this ESI file.
- Delete
ESICache.xml from the RMP folder. The RMP makes a new one.
- Replace your
0x13AF Product entry with the entry below.
- Restart the RMP. Generate the ENI. Start the network.
Read these notes before you change the file:
- CustomNodeInfo.xml matches on Product Code only. Thus one entry with
AxisCount 4 applies to all models.
- On the AZD3A-KED, the 4th RMP axis has no PDOs. Do not use that axis.
- Change only PDOs that are on all models: axes 1 to 3 (
0x1600–0x1623, 0x1A00–0x1A23) and the controller (0x1700, 0x1B00). If you add or remove a 4th-axis PDO, the 3-axis drive fails.
- Keep a name for each object on each axis: StatusWord, ControlWord, PositionActual, PositionDemand, ModeOfOperation and digital inputs. If a name is missing, the RMP can connect that axis to an axis 1 object.
- Axes 1 to 3 use Transmit PDO mapping 4, which has digital inputs. Axis 4 uses the default mapping 1, which has no digital inputs.
- The digital input bits are the CiA 402 defaults: bit 0 negative limit, bit 1 positive limit, bit 2 home. Make sure they agree with the AZD manual.
CustomNodeInfo.xml
<EtherCATNodeInfo>
<Vendors>
<Vendor Id="0x2BE">
<VendorName>ORIENTAL MOTOR CO.,LTD.</VendorName>
<!-- AZD2A/3A/4A-KED: same Product Code 0x13AF. This one entry applies to all of them. -->
<Product Code="0x13AF">
<ProductName>AZDxA-KED</ProductName>
<ShortName>Oriental AZDxA-KED</ShortName>
<ItemSubType>Drive</ItemSubType>
<AxisCount>4</AxisCount>
<PDOs>
<!-- Only PDOs that all models have (axes 1 to 3). -->
<PDOAssignment Index="0x1A00" IsOutput="False" Include="False"/>
<PDOAssignment Index="0x1A03" IsOutput="False" Include="True"/>
<PDOAssignment Index="0x1A10" IsOutput="False" Include="False"/>
<PDOAssignment Index="0x1A13" IsOutput="False" Include="True"/>
<PDOAssignment Index="0x1A20" IsOutput="False" Include="False"/>
<PDOAssignment Index="0x1A23" IsOutput="False" Include="True"/>
</PDOs>
<StatusWord>Axis1 Transmit PDO mapping 4.Statusword</StatusWord>
<PositionActual>Axis1 Transmit PDO mapping 4.Position actual value</PositionActual>
<ControlWord>Axis1 Receive PDO mapping 1.Controlword</ControlWord>
<PositionDemand>Axis1 Receive PDO mapping 1.Target position</PositionDemand>
<ModeOfOperation>Axis1 Receive PDO mapping 1.Modes of operation</ModeOfOperation>
<IO>
<DigitalInputItems>
<DigitalInput SigBits="0x00000007" Size="32" NegLimit="0" PosLimit="1" Home="2">Axis1 Transmit PDO mapping 4.Digital inputs</DigitalInput>
</DigitalInputItems>
</IO>
<AdditionalAxes>
<Axis Index="1">
<StatusWord>Axis2 Transmit PDO mapping 4.Statusword</StatusWord>
<PositionActual>Axis2 Transmit PDO mapping 4.Position actual value</PositionActual>
<ControlWord>Axis2 Receive PDO mapping 1.Controlword</ControlWord>
<PositionDemand>Axis2 Receive PDO mapping 1.Target position</PositionDemand>
<ModeOfOperation>Axis2 Receive PDO mapping 1.Modes of operation</ModeOfOperation>
<IO>
<DigitalInputItems>
<DigitalInput SigBits="0x00000007" Size="32" NegLimit="0" PosLimit="1" Home="2">Axis2 Transmit PDO mapping 4.Digital inputs</DigitalInput>
</IO>
</Axis>
<Axis Index="2">
<StatusWord>Axis3 Transmit PDO mapping 4.Statusword</StatusWord>
<PositionActual>Axis3 Transmit PDO mapping 4.Position actual value</PositionActual>
<ControlWord>Axis3 Receive PDO mapping 1.Controlword</ControlWord>
<PositionDemand>Axis3 Receive PDO mapping 1.Target position</PositionDemand>
<ModeOfOperation>Axis3 Receive PDO mapping 1.Modes of operation</ModeOfOperation>
<IO>
<DigitalInputItems>
<DigitalInput SigBits="0x00000007" Size="32" NegLimit="0" PosLimit="1" Home="2">Axis3 Transmit PDO mapping 4.Digital inputs</DigitalInput>
</IO>
</Axis>
<Axis Index="3">
<!-- Axis 4: AZD4A-KED only. The AZD3A-KED has no PDOs for this axis. -->
<StatusWord>Axis4 Transmit PDO mapping 1.Statusword</StatusWord>
<PositionActual>Axis4 Transmit PDO mapping 1.Position actual value</PositionActual>
<ControlWord>Axis4 Receive PDO mapping 1.Controlword</ControlWord>
<PositionDemand>Axis4 Receive PDO mapping 1.Target position</PositionDemand>
<ModeOfOperation>Axis4 Receive PDO mapping 1.Modes of operation</ModeOfOperation>
<!-- Mapping 1 has no digital inputs. Keep this name: it stops axis 4 from using the axis 1 inputs. -->
<IO>
<DigitalInputItems>
<DigitalInput SigBits="0x00000007" Size="32" NegLimit="0" PosLimit="1" Home="2">Axis4 Transmit PDO mapping 4.Digital inputs</DigitalInput>
</IO>
</Axis>
</AdditionalAxes>
</Product>
</Vendor>
</Vendors>
</EtherCATNodeInfo>
Next
We will start work on an optional Revision attribute for Product in CustomNodeInfo.xml:
<Product Code="0x13AF" Revision="0x01110301"> <!-- used only for this exact Revision Number -->
<Product Code="0x13AF"> <!-- used for all other Revision Numbers -->
Then each model can have its own entry, for example AxisCount 3 for the AZD3A-KED, with no unused axis. We will post here when it is available.
