Anecdotal evidence suggests that it corresponds to the value returned from MotionCountGet().
I’m debating about how to implement some behavior, and I need to know whether adding another object will ding the axis count (and incur additional expense).
It is counting RMP Axis objects (real or phantom), it’s using the same thing you can read using AxisCountGet(). RapidSetup shows you the Axis License Count.
MotionCount does not have any licensed restrictions.
In RapidSetup, if I set the axis count equal to the axis count in the license, then try to add a single multi axis, I see this error:
Control: motionCount is invalid :: {control.c, line 8820} : MPIControlConfig.dynamicMemAlloc.motionSupervisorCount: 65 is out of range, the valid range is 0 to 64. (Error 1549) (MotionController::ControlConfigSet) (Object 0) (File motioncontroller.cpp) (Line 1297) (Version 10.3.1.0)
If I reduce the axis count by one, then adding a single multiaxis succeeds.
