This was a benign issue but I thought I should let you know. We often run our software with RapidSetup running at the same time which is handy for monitoring the servos and other devices. On this particular occasion we also had RapidWorkbench loaded as we were checking the Digital I/Os on the one of the servos. It got left that way overnight and this morning the following error was displayed:
Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore the error and attempt to continue.
Exception of type “System.OutOfMemoryException” was thrown.
I looked at the details and could see the stack trace went back to RapidWorkbench. I was able to continue and close RapidWorkbench down, and there was no impact on our application.
We are running a back rev of the RSI software (8.1.6).
