Does RMP only support the EtherCAT line topology for sync groups? Any support for ring or star?
Hi in101, thank you for the question. Short answer: sync groups work in line and tree (“star”) topologies today. Ring is not in a release yet.
Line
This is the standard layout (sync groups shipped in RMP 11.1.0). When you disconnect a node in a line, you also disconnect all nodes after it. Thus, put removable groups at the end of the line.
Star / tree
EtherCAT does not use Ethernet switches. To make a star, use an EtherCAT junction, for example the Beckhoff CU1128 or CU1124. Put each removable section on its own junction port. Then, when you disconnect one branch, the other branches continue to operate.
We tested a CU1128 with sync groups in our lab. When we disconnected a branch, only that group stopped. The network and the other groups continued, and an axis on a different branch continued to move.
Some limits apply. The most important one: when you connect a branch again, the full network loses frames for a short time. Thus, moving axes on other branches can get a fault. We can give you more details for your layout.
Ring (cable redundancy)
We are working on this now, and the first hardware results are good. It is not in a release, and we do not have a date yet.
Please tell us about your application
- Do you need to survive a cable or node failure, or do you need to connect and disconnect machine sections?
- How many nodes and axes? What cycle rate and OS?
- Which nodes are removable?
- Must the other axes continue to move when a section is disconnected or connected again?
We can also review your layout or test it on our bench with your hardware.
