Two-Step Network Start
Avatar: RapidSetup
RapidSetup gives you the power to discover, (generate a new ENI—not discussed here), and start.
Is there documentation regarding accomplishing this within RapidCode?
Discovery
I would guess that that discovery would not attempt to make the network operational. In the API (NetworkStart()), I assume should I choose RSINetworkStartModePREOPERATIONAL as the start mode and RSINetworkStartupMethodPROBE_TOPOLOGY as the startup method. Is that correct?
Result / Errors?
How do I discern success/failure? Does in throw exceptions?
When I discover in RapidSetup, the state at the end of the operation is RSINetworkState_SHUTDOWN. I might have expected it to be RSINetworkState_PREOPERATIONAL, but I don’t really know what to expect.
What should I expect?
Network Start
For this, I assume that I need to set the startup method to RSINetworkStartupMethodNETWORK_ONLY and the start mode to RSINetworkStartModeOPERATIONAL.
Result / Errors?
Is checking the network state (against operational) sufficient for success? Will it throw exceptions?
