Can I only specify a remote server in RapidSetupX using an IPv4 address?
Resolving hostnames would be convenient.
That’s correct. RapidSetupX allows you to discover RapidServers on your network automatically or connect manually by specifying your RapidServer’s IPv4 address. We’ll discuss the possibility of adding hostname support and see what we can do.
To connect manually, enable Developer Mode in the Settings section. This will display the Manual card in the Servers page in RapidSetupX
Manually specifying a remote server is what I was thinking about.
