We recently upgraded from 10.3.8 to 10.4.3. Here are some observations, FWIW.
Full Disclosure: I use RapidSetup as a troubleshooting tool, and not as the means by which we run RMP.
- Network I/O
- This is a great idea. I like having everything in one place.
- I like the one-click state toggling.
- The columns are barely resizable. At least, I cannot resize a category, so resizing individual columns doesn’t provide much benefit.
- Maximizing the window only helps a little.
- Hiding columns: very useful.
- I would sort of expect the other (visible) columns grow horizontally, but this doesn’t happen.
- I tried this hoping to increase column size so I could see (and distinguish long names), but it wasn’t helpful.
- Filtering
- The filtering is also an excellent idea.
- The filter string looks to be a series of required words, joined with a logical AND (requiring all of them).
- It seems more useful for this list of words were logically OR’d together.
- I would guess that people would want to filter IN I/O points with different names/keywords rather than filtering out more nodes.
- Another option would be to allow logical operators in the search string (though that might not appeal to many customers, IDK)
- The filter string is not (re-)applied when you restart the network. What I typed in still appears in the text entry box, but it isn’t applied. I have to change the value to get it to apply.
- It would be OK if you cleared the value and didn’t apply any filter, too. The current behavior just seems wierd.
- The text entry is very small, though there’s a lot of room for it to be longer. Perhaps you weren’t expecting long strings (sensible).
- I/O nodes can be renamed: This is very useful to me, since we usually need to distinguish between them by some means quicker than node order.
- The names do not seem to persist between invocations of RapidSetup.
- The names of the individual I/O points persist, but not the names of the I/O nodes (in the navigation portion of the window on the left).
- It seems like I can rename Axis nodes via the API and have the names persist. It would be cool if this worked for I/O nodes in the same way. I could live with restrictions, like max 16 or 32 chars. Anything to allow me to label things for quick and unambiguous distinction would be good enough.
