[INtime 6][INtime 7]
Is there a way to programmatically configure INtime (nodes)? I’d like to be able to automate installation/configuration, but I’m not sure how to do it.
Can you point me in the right direction?
todd.
todd.
The INtime runtime ships with the Local Node Configuration Library (INtime SDK Help). We use this internally to set up new systems, so I expect you should be able to use it to configure almost everything.
The headers, linking libraries, and runtime libraries should be located at “%INTIME%/nt/include”, “%INTIME%/nt/lib”, and “%INTIME%/bin” respectively. Keep an eye out for the 64 bit LNC files if you are building for 64 bit.
Let me know how this works out.
Stefan
Does the runtime (e.g. the files you host on the portal) ship with this? I don’t see any of those directories on my machine running 6.4.21350.1.
