8.1.3
April 2, 2019
- [New] RapidSetup Axis and MultiAxis repeat motion disabled on errors, amp disabled, and switching views.
- [New] RMPNetwork sets Amp Fault for each axis on shutdown.
- [New] UserLimit methods now use cached AxisCount to improve performance.
- [New] SourceNameGet() no longer throws exceptions when it cannot read extra Amp Fault text.
- [Fix] RapidSetup ā SDO Read/Write string values.
- [Fix] 64-bit RapidCode libraries now support tracing and home logging.
- [Fix] RMPNetwork intermittent shutdown issues with node power loss/disconnection.
- [Fix] RapidSetup ā Axis Master-based Homing issues (reversed Move To Zero and Log Homing).
- [Fix] RapidSetup ā unable to set Home Method 18.
