New Release - 10.6.8
Hi,
We’ve got a new release today with the following changelog:
  • @new Delta ASDA-B3A drive support .
  • @new Synapticon SOMANET Integro drive support.
  • @new MotionController::CreationParametersGet().
  • @update RapidSetupX - improved polling.
  • @update RapidCodeRemote MotionControllerCreationParameters added for Action.Create and Info.
  • @update RapidSetupX - prevent X from terminating connection on server first ping failure
  • @update rapidserver - uses less RAM at idle and handles significantly higher concurrency under load.
  • @fix Linux - ARM-only issue prevented synchronization for nodes with 64 bit clocks.
  • @fix RapidSetupX - axis page decimal places auto set based on userunits.
  • @fix RapidSetupX - axis page move buttons disabling.
  • @fix RapidCode - Axis HomeState supports 64 axes.
  • @fix MotionController::Get() no longer requires rsi.lic in the executable path.
  • @fix RapidSetupX - Only read recorder data when explicitly requested by the user
