New Release - 10.6.7
10.6.7 Mar 13, 2025
  • @new RapidCode - Axis::PostTrajectoryGearingScaledOffsetGet().
  • @new RapidCode - Axis::DigitalInputs/OutputsGet(), Axis::DedicatedInputs/OutputsGet().
  • @new RapidCode.NET XML and Python documentation for improved IDE experience.
  • @new RapidCodeRemote - Axis Status general digital inputs and outputs.
  • @new RapidCodeRemote - Axis Config FeedRate.
  • @new RapidCodeRemote - Axis Action for OperationMode.
  • @new RapidSetupX - Axis feed rate and operation mode added.
  • @new RapidSetupX - navigation controller item axes-clear faults/enable right-click commands.
  • @new RMPNetwork - NetworkNode axis count set during discovery.
  • @update RMPNetwork - simplified, expanded, and improved NetworkLogMessages.
  • @update RapidCode - Axis::StatusBitsGet() improved execution speed.
  • @update RapidENI - FSoE Automatic safety byte alignment when generating.
  • @update Windows - RMP EtherCAT sample rates limited by INtime Kernel Clock Rate.
  • @update rsiconfig - Linux - globalization-invariant mode for Docker compatibility.
  • @update rapidserver - Linux - set WorkingDirectory to /rsi for rapidserver.service.
  • @fix rapidserver - RecorderCount greater than 16 allowed.
  • @fix RapidSetupX - MultiAxis data not updating.
