10.6.1
Sep 16, 2024
- [New] Linux -
sudono longer required. - [New] RapidSetupX - Axis move furthest button and repeat motion feature.
- [New] RapidSetupX - Scope trigger on motion.
- [New] RapidSetupX - NIC field autocomplete.
- [New] RapidCode - MotionController::RecorderTriggerOnMotionGet().
- [New] RapidCodeRemote - Recorder Configuration trigger on motion added.
- [New] RapidCodeRemote - add short_message to ErrorMessage
- [Change] RapidCode - MotionController::MemoryGet improvements for speed and safety.
- [Change] RMPNetwork - Better identification of Wago IO.
- [Change] Linux - improved permissions error messages.
- [Change] Linux - All RMP and RapidCode shared memory objects now start with
RSI. - [Change] Linux - RMP process will not exit if its creating process is terminated.
- [Change] ESI cache parsing errors logged to RapidENI.log.
- [Change] RapidSetupX - Textbox validation error readability.
- [Change] RapidSetupX - Scope markers added and circular buffer render improvements.
- [Change] RapidSetupX - Logged errors copy functionality improved.
- [Fix] RapidSetupX - Scope render freeze on Linux.
- [Fix] RapidSetupX - List filtering.
