In fact, while my app is running and not doing anything homing-related, the Home Limit is active.
Curiously, my appās input that corresponds to RSIMotorDedicatedInHOME
is low. Its value is the result of DedicatedInGet(...)
I guess the āHome Limitā bit isnāt a dedicated input.
Where would I find this bit?
10.3.1:
The home method would consider the home limit active if:
The dedicated IO ==HIGH
OR if HomeLimitCustomConfigSet() has been called
The custom config address value == HIGH
10.3.2:
The home method will consider the home limit active it the
Dedicated IO == HomeTriggerStateGet()
The custom config address value == HomeTriggerStateGet()
Assuming the correct state for HomeTriggerStateSet this shouldnāt have changed your behavior.
No, it should reflect the custom home state if you have one (or its opposite depending on trigger state).
I am working to reproduce your custom config here and see if I can repeat the erroneous behavior. Iāll let you know what I discover.
It should be whatever bit you used for your call to customConfigSet. That and the HomeTriggerState should be the only two things that can change what HomeLimitGet() returns.
Was able to reproduce the issue.
Havenāt fully nailed it down yet but Iāve got a good hunch.
There should be a fix for this bug in 10.3.4
