Will the I/O (or generally, bit in memory) work for any homing method that involves a limit or home switch?
Consider these homing methods defined in the API.
NEGATIVE_LIMIT_THEN_RIGHT_INDEX = 1
POSITIVE_LIMIT_THEN_LEFT_INDEX = 2
RISING_HOME_THEN_LEFT_INDEX = 3
RISING_HOME_THEN_RIGHT_INDEX = 4
FALLING_HOME_THEN_RIGHT_INDEX = 5
FALLING_HOME_THEN_LEFT_INDEX = 6
RISING_HOME_THEN_LEFT_INDEX_POSITIVE_START = 7
RISING_HOME_THEN_RIGHT_INDEX_POSITIVE_START = 8
FALLING_HOME_THEN_LEFT_INDEX_POSITIVE_START = 9
FALLING_HOME_THEN_RIGHT_INDEX_POSITIVE_START = 10
FALLING_HOME_THEN_RIGHT_INDEX_NEGATIVE_START = 11
FALLING_HOME_THEN_LEFT_INDEX_NEGATIVE_START = 12
RISING_HOME_THEN_RIGHT_INDEX_NEGATIVE_START = 13
RISING_HOME_THEN_LEFT_INDEX_NEGATIVE_START = 14
NEGATIVE_LIMIT = 17
POSITIVE_LIMIT = 18
RISING_HOME = 19
POSITIVE_HOME_1 = 20
FALLING_HOME = 21
NEGATIVE_HOME_1 = 22
RISING_HOME_POSITIVE_START = 23
RISING_HOME_FROM_NEGATIVE_SIDE_POSITIVE_START = 24
FALLING_HOME_POSITIVE_START = 25
RISING_HOME_FROM_POSITIVE_SIDE_POSITIVE_START = 26
FALLING_HOME_NEGATIVE_START = 27
RISING_HOME_FROM_NEGATIVE_SIDE_NEGATIVE_START = 28
RISING_HOME_NEGATIVE_START = 29
RISING_HOME_FROM_POSITIVE_SIDE_NEGATIVE_START = 30
Will all these work with the custom config set (as opposed to the dedicated, drive-only, I/O defined in EtherCATNodeInfo.xml)?
