Dewesoft IOLITE STG
Support for dewesoft iolite ethercat modules. we are using an dewesoft ethercat node to condition and bring in torque from a load cell. If we have the esi file from the vendor how do we add support for the device.
Currently we have put the ESI file into the folder, cleared the cache, and regenerated the ENI file. This was successful but we can start the network because i think that the SW doesnt know what to do with the node.
Could we get guidance on the next steps?
Hi Justin,
You will need to mock up a customNodeInfo with the relevant Vendor ID, Product Code, etc. In /rsi/x.x.x you will find customNodeInfo.xml, make your edits there. More information here
If you share the ESI we can get help get you started.
thanks for the response. we are checking out the documentation. here is the esi
<?xml version="1.0" encoding="utf-8"?>
<EtherCATInfo xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="EtherCATInfo.xsd" Version="1.6">
  <Vendor>
    <Id>#xDEBE50F7</Id>
    <Name>Dewesoft</Name>
    <ImageData16x14>424DE6000000000000007600000028000000100000000E000000010004000000000070000000C40E0000C40E000000000000000000000000000000008000008000000080800080000000800080008080000080808000C0C0C0000000FF0000FF000000FFFF00FF000000FF00FF00FFFF0000FFFFFF00DDDDDDDDDDDDDDDDD9999999999999DDDD99999999999DDDD9DD9999999DD9DDD999DD999DD999DDDD9999D9D9999DDDDD99999D99999DDDDDD9999D9999DDDDDDD9999D9999DDDDDDDD999D999DDDDDDDDD999D999DDDDDDDDDD99D99DDDDDDDDDDDD9D9DDDDDDDDDDDDDDDDDDDDDDD</ImageData16x14>
  </Vendor>
  <Descriptions>
    <Groups>
      <Group SortOrder="0">
        <Type>IOLITE</Type>
        <Name LcId="1031">IOLITE</Name>
        <Name LcId="1033">IOLITE</Name>
      </Group>
    </Groups>
    <Devices>
      <Device Physics="KK">
        <Type ProductCode="252" RevisionNo="#x00010000">IOLITEr 6xSTG</Type>
        <Name LcId="1033">IOLITEr 6xSTG</Name>
        <Name LcId="1031">IOLITEr 6xSTG</Name>
        <Info>
          <StateMachine>
            <Timeout>
              <PreopTimeout>2000</PreopTimeout>
              <SafeopOpTimeout>9000</SafeopOpTimeout>
              <BackToInitTimeout>5000</BackToInitTimeout>
              <BackToSafeopTimeout>200</BackToSafeopTimeout>
            </Timeout>
          </StateMachine>
          <Mailbox>
            <Timeout>
              <RequestTimeout>100</RequestTimeout>
              <ResponseTimeout>2000</ResponseTimeout>
            </Timeout>
          </Mailbox>
        </Info>
        <GroupType>IOLITE</GroupType>
        <Profile>
          <ProfileNo>5001</ProfileNo>
          <AddInfo>0</AddInfo>
          <ChannelCount>6</ChannelCount>
        </Profile>
        <Fmmu Sm="2">Outputs</Fmmu>
        <Fmmu Sm="3">Inputs</Fmmu>
        <Fmmu Sm="4">Outputs</Fmmu>
        <Fmmu Sm="5">Inputs</Fmmu>
        <Fmmu>MBoxState</Fmmu>
        <Sm MinSize="34" MaxSize="192" DefaultSize="128" StartAddress="#x1000" ControlByte="#x26" Enable="1">MBoxOut</Sm>
        <Sm MinSize="34" MaxSize="192" DefaultSize="128" StartAddress="#x1200" ControlByte="#x22" Enable="1">MBoxIn</Sm>
        <Sm DefaultSize="2" StartAddress="#x1400" ControlByte="#x64" Enable="1">Outputs</Sm>
        <Sm DefaultSize="6" StartAddress="#x1800" ControlByte="#x20" Enable="1">Inputs</Sm>
        <Sm DefaultSize="2" StartAddress="#x1f00" ControlByte="#x24" Enable="1">Outputs</Sm>
        <Sm DefaultSize="6" StartAddress="#x1f80" ControlByte="#x20" Enable="1">Inputs</Sm>
        <Mailbox DataLinkLayer="true">
          <CoE SdoInfo="true" PdoAssign="true" PdoUpload="true" PdoConfig="true" SegmentedSdo="true" CompleteAccess="true">
            <InitCmd>
              <Transition>IP</Transition>
              <Index>32800</Index>
              <SubIndex>9</SubIndex>
              <Data>0100</Data>
              <Comment>Bus1 mode: 0000 = DC, 0300 = SM, 0100 = buffered DC (DEWESoft)</Comment>
            </InitCmd>
            <InitCmd>
              <SubIndex>10</SubIndex>
              <Data>0300</Data>
              <Comment>Bus2 mode: 0000 = DC, 0300 = SM</Comment>
            </InitCmd>
          </CoE>
          <FoE/>
        </Mailbox>
        <Dc>
          <OpMode>
            <Name>unbuff-SM</Name>
            <Desc>SM Sync</Desc>
            <AssignActivate>#x0</AssignActivate>
            <CycleTimeSync0 Factor="1">0</CycleTimeSync0>
            <ShiftTimeSync0>0</ShiftTimeSync0>
            <CycleTimeSync1 Factor="1">0</CycleTimeSync1>
          </OpMode>
          <OpMode>
            <Name>unbuff-DC-bus2</Name>
            <Desc>Bus2 DC Sync</Desc>
            <AssignActivate>#x700</AssignActivate>
            <CycleTimeSync0>1000000000</CycleTimeSync0>
          </OpMode>
          <OpMode>
            <Name>DC-bus1</Name>
            <Desc>Bus1 DC Sync</Desc>
            <CycleTimeSync0>1000</CycleTimeSync0>
            <CycleTimeSync1 Factor="-1000">0</CycleTimeSync1>
          </OpMode>
        </Dc>
        <Eeprom>
          <ByteSize>2048</ByteSize>
          <ConfigData>050C0044320000000000</ConfigData>
          <BootStrap>0010800000128000</BootStrap>
        </Eeprom>
      </Device>
        <Type ProductCode="252" RevisionNo="#x00010001">IOLITEr 6xSTG Bus1</Type>
        <Name LcId="1033">IOLITEr 6xSTG Bus1</Name>
        <Name LcId="1031">IOLITEr 6xSTG Bus1</Name>
        <Info>
          <StateMachine>
            <Timeout>
            </Timeout>
          </StateMachine>
          <Mailbox>
            <Timeout>
            </Timeout>
          </Mailbox>
        </Info>
        <Profile>
        </Profile>
        <TxPdo Sm="3">
          <Index>#x1a20</Index>
          <Name>UnBuf TxPDO-Map</Name>
          <Entry>
            <Index>#x6030</Index>
            <SubIndex>1</SubIndex>
            <BitLen>32</BitLen>
            <Name>u1</Name>
            <DataType>REAL</DataType>
          </Entry>
          <Entry>
            <SubIndex>2</SubIndex>
            <BitLen>32</BitLen>
            <Name>u2</Name>
          </Entry>
          <Entry>
            <SubIndex>3</SubIndex>
            <BitLen>32</BitLen>
            <Name>u3</Name>
          </Entry>
          <Entry>
            <SubIndex>4</SubIndex>
            <BitLen>32</BitLen>
            <Name>u4</Name>
          </Entry>
          <Entry>
            <SubIndex>5</SubIndex>
            <BitLen>32</BitLen>
            <Name>u5</Name>
          </Entry>
          <Entry>
            <SubIndex>6</SubIndex>
            <BitLen>32</BitLen>
            <Name>u6</Name>
          </Entry>
        </TxPdo>
          <CoE SdoInfo="true" PdoAssign="true" PdoConfig="true" SegmentedSdo="true" CompleteAccess="true">
            <InitCmd>
              <Data>0300</Data>
            </InitCmd>
          </CoE>
          <FoE/>
        </Mailbox>
        <Dc>
          <OpMode>
            <Name>SM</Name>
          </OpMode>
          <OpMode>
            <Name>DC</Name>
            <Desc>DC Sync</Desc>
          </OpMode>
        </Dc>
        <Eeprom>
        </Eeprom>
      </Device>
        <Type ProductCode="252" RevisionNo="#x00011001">IOLITEr 6xSTG Bus2</Type>
        <Name LcId="1033">IOLITEr 6xSTG Bus2</Name>
        <Name LcId="1031">IOLITEr 6xSTG Bus2</Name>
        <Info>
          <StateMachine>
            <Timeout>
            </Timeout>
          </StateMachine>
          <Mailbox>
            <Timeout>
            </Timeout>
          </Mailbox>
        </Info>
        <Profile>
        </Profile>
        <TxPdo Sm="3">
          <Entry>
            <BitLen>32</BitLen>
            <Name>u1</Name>
          </Entry>
          <Entry>
            <BitLen>32</BitLen>
            <Name>u2</Name>
          </Entry>
          <Entry>
            <BitLen>32</BitLen>
            <Name>u3</Name>
          </Entry>
          <Entry>
            <BitLen>32</BitLen>
            <Name>u4</Name>
          </Entry>
          <Entry>
            <BitLen>32</BitLen>
            <Name>u5</Name>
          </Entry>
          <Entry>
            <BitLen>32</BitLen>
            <Name>u6</Name>
          </Entry>
        </TxPdo>
            <InitCmd>
              <Data>0300</Data>
            </InitCmd>
          </CoE>
          <FoE/>
        </Mailbox>
        <Dc>
          <OpMode>
            <Name>SM</Name>
          </OpMode>
          <OpMode>
            <Name>DC</Name>
          </OpMode>
        </Dc>
        <Eeprom>
        </Eeprom>
      </Device>
      <Device Physics="YY">
        <Type ProductCode="252" RevisionNo="#x00020000">IOLITE 6xSTG</Type>
        <Name LcId="1033">IOLITE 6xSTG</Name>
        <Name LcId="1031">IOLITE 6xSTG</Name>
        <Info>
          <StateMachine>
            <Timeout>
            </Timeout>
          </StateMachine>
          <Mailbox>
            <Timeout>
            </Timeout>
          </Mailbox>
        </Info>
        <Profile>
        </Profile>
            <InitCmd>
              <Data>0300</Data>
            </InitCmd>
          </CoE>
          <FoE/>
        </Mailbox>
        <Dc>
          <OpMode>
          </OpMode>
          <OpMode>
            <Name>DC</Name>
          </OpMode>
        </Dc>
        <Eeprom>
        </Eeprom>
      </Device>
        <Type ProductCode="252" RevisionNo="#x00020001">IOLITE 6xSTG</Type>
        <Info>
          <StateMachine>
            <Timeout>
            </Timeout>
          </StateMachine>
          <Mailbox>
            <Timeout>
            </Timeout>
          </Mailbox>
        </Info>
        <Profile>
        </Profile>
        <TxPdo Sm="3">
          <Entry>
            <BitLen>32</BitLen>
            <Name>u1</Name>
          </Entry>
          <Entry>
            <BitLen>32</BitLen>
            <Name>u2</Name>
          </Entry>
          <Entry>
            <BitLen>32</BitLen>
            <Name>u3</Name>
          </Entry>
          <Entry>
            <BitLen>32</BitLen>
            <Name>u4</Name>
          </Entry>
          <Entry>
            <BitLen>32</BitLen>
            <Name>u5</Name>
          </Entry>
          <Entry>
            <BitLen>32</BitLen>
            <Name>u6</Name>
          </Entry>
        </TxPdo>
            <InitCmd>
              <Data>0300</Data>
            </InitCmd>
          </CoE>
          <FoE/>
        </Mailbox>
        <Dc>
          <OpMode>
          </OpMode>
          <OpMode>
            <Name>DC</Name>
          </OpMode>
        </Dc>
        <Eeprom>
        </Eeprom>
      </Device>
        <Type ProductCode="#x9E" RevisionNo="#x00100002">IOLITEi-1xSTG</Type>
        <Name LcId="1033">IOLITEi-1xSTG</Name>
        <Name LcId="1031">IOLITEi-1xSTG</Name>
        <Info>
          <StateMachine>
            <Timeout>
            </Timeout>
          </StateMachine>
          <Mailbox>
            <Timeout>
            </Timeout>
          </Mailbox>
          <IdentificationReg134>false</IdentificationReg134>
        </Info>
        <Profile>
          <ChannelCount>1</ChannelCount>
        </Profile>
        <Fmmu>Outputs</Fmmu>
        <Fmmu>Inputs</Fmmu>
        <Sm MinSize="34" MaxSize="128" DefaultSize="128" StartAddress="#x1000" ControlByte="#x26" Enable="1">MBoxOut</Sm>
        <Sm MinSize="34" MaxSize="128" DefaultSize="128" StartAddress="#x1080" ControlByte="#x22" Enable="1">MBoxIn</Sm>
        <Sm DefaultSize="0" StartAddress="#x1100" ControlByte="#x64" Enable="1">Outputs</Sm>
        <Sm DefaultSize="6" StartAddress="#x1400" ControlByte="#x20" Enable="1">Inputs</Sm>
        <TxPdo Sm="3">
          <Index>#x1a01</Index>
          <Name>DI</Name>
          <Entry>
            <Index>#x6000</Index>
            <BitLen>16</BitLen>
            <Name>Frame Counter</Name>
            <DataType>UINT</DataType>
          </Entry>
        </TxPdo>
        <TxPdo Sm="3">
          <Name>AI</Name>
          <Entry>
            <Index>#x6020</Index>
            <BitLen>32</BitLen>
            <Name>CH1</Name>
            <DataType>DINT</DataType>
          </Entry>
        </TxPdo>
          <EoE/>
          <CoE SdoInfo="true" SegmentedSdo="true" CompleteAccess="true" PdoAssign="true" PdoConfig="true">
            <InitCmd>
              <SubIndex>07</SubIndex>
              <Data>00</Data>
              <Comment>BufferedInput</Comment>
            </InitCmd>
          </CoE>
          <FoE/>
        </Mailbox>
        <Dc>
          <OpMode>
            <Name>SM-Sync-PLL</Name>
            <Desc>SM-Sync-PLL</Desc>
            <CycleTimeSync1 Factor="1000">0</CycleTimeSync1>
          </OpMode>
          <OpMode>
            <Name>SM-Sync-PLLOff</Name>
            <Desc>SM-Sync-PLLOff</Desc>
            <AssignActivate>#x00</AssignActivate>
            <CycleTimeSync0>0</CycleTimeSync0>
            <CycleTimeSync1 Factor="0">0</CycleTimeSync1>
          </OpMode>
        </Dc>
        <Eeprom>
          <ConfigData>800E00CC3f00ff00000000800000</ConfigData>
          <BootStrap>0010000100180001</BootStrap>
        </Eeprom>
      </Device>
    </Devices>
  </Descriptions>
</EtherCATInfo>
