New Release 11.1.1
We have a new release today, now available for download on RapidPortal.
Have a look at the changelog below:
11.1.1 Oct 7, 2026
  • @new Kollmorgen Essentials drive support.
  • @new MOONS SSDC06-ECX-mini support.
  • @new MOONS SSDC06-2XU-ECX-S support.
  • @new RapidCode - Axis fault and limit TriggerSampleGet() methods report when each last triggered.
  • @new RapidCode - NetworkNode::AddressGet() and recordable NetworkStatus/NodeStatus values.
  • @new RapidCode - RapidCodeNetworkNode::Status reports SDO read/write and AKD ASCII request and failure counts.
  • @new NetworkNode and I/O user labels in RapidCode, RapidCodeRemote, RapidSetupX, and rsiconfig.
  • @update RapidCode - Axis::CommandPositionDirectSet() returns without waiting for the firmware.
  • @update RapidCode - Axis position setters and OriginPositionGet() no longer queue behind other controller writes.
  • @update RapidCode - Axis::SourceNameGet() reads the drive’s amp fault text once per fault.
  • @update G-Code - feed rate and acceleration are required only for feed-governed motion.
  • @update G-Code - a unit change clears the feed rate until the program restates it.
  • @update Linux - multi-process locks match Windows named-mutex behavior.
  • @update RMPNetwork - AKDASCIICommand() uses less shared memory.
  • @update rapidserver - GetInfo reports the host’s isolated CPU IDs and Ethernet NIC names on Linux.
  • @fix RMP - electronic gearing superimposes with point-to-point motion on the geared axis.
  • @fix RMP - a triggered or e-stop modify no longer loads frames onto a non-moving MultiAxis member.
  • @fix RapidCode - MemoryDoubleSet() and the Axis position setters complete within one sample.
  • @fix G-Code - callbacks restore their load-time acceleration.
  • @fix RMPNetwork - service-channel startup preserves cyclic frame timing.
  • @fix RMPNetwork - network timing supports INtime CPUs above 4.29 GHz.
